Sidestay back plate pulling through hull
Hi all. First post, but I think I read through the entire forum as we bought a DS this spring. She's an '84 25th anniversary edition - and our first boat. (Though I grew up sailing down south - mainly on Sunfish, Hobies, and larger cruisers)
We've been having a blast - exploring the Boston harbor on her nearly every weekend. Last weekend, humming along in medium air and a three foot chop crossing the channel, we heard a small slight pop under the hull. I assumed we'd just brushed up against a lobster buoy. On inspection back home I noticed the chainplate backup on the port stay had cracked the fiberglass, and was causing some separation in a small area between the hull and deck.
I assume this is the noise we heard, and that this is a new occurrence. The sail home went fine, and things still feel fairly solid when I put some weight on the stay. I don't even think we were taking any water on.
Questions are how worried should I be, and would getting a longer back plate (from DR Marine possibly?) be enough support?
What would you guys suggest as a the best course of action for someone not super comfortable with glass work, and anxious to safely get back on the water ASAP?
Here are a few pics: https://www.icloud.com/journal/#2;CAEQA ... 7646DA5726
Thanks - Jon
Thanks - Jon
