GreenLake wrote:Check D&R Marine. Last I checked they sold the rubrail material (outer, rubber-like stuff and inner PVC guides). You should be able to replace yours entirely and it would make the boat look better. (There are end caps that mount at the transom, check pictures of other boats. If yours are missing you'd have to find a way to replace them).
GreenLake wrote:Your hull deck joint does not require glassing unless it shows signs of failure. That said, you might want to glass the joint in the very front of the boat, the area that would get slammed when you sail the DS into chop.
PassingWind wrote:Actually what I wanted to do was remove the bumper and fiberglass tabs completely.. Glass from the inside to strengthen the bond between the hull and deck.
The DS will not be on a dock it will be launched via a trailer from the my property. It would be moored if left in the water.
GreenLake wrote:PassingWind wrote:Actually what I wanted to do was remove the bumper and fiberglass tabs completely.. Glass from the inside to strengthen the bond between the hull and deck.
Sure, you could do that - however, it could render your DS not "class - legal" because it changes the outer dimensions of the hull. That matters only if you intend to join others in races under class rules, or, if you ever contemplate selling it to someone who does.
As long as your ramp doesn't have a dock, and as long as you don't race (both from rules perspective and from the chance of getting too close to another boat) I see no reason why you couldn't be happy with a rail-free DS.
In that case, glassing the joint is a suitable precaution against possible loss of strength - check the part you are intending to cut off and see whether it contains a significant "lip" for the joint. I think it does. In that case, make your inside glass substantial enough to provide the same strength. (Also, goes without saying, you want to be really good in preparing the surface - remove paint, degrease, roughen).
PassingWind wrote:As for as the noodle info above, I am planning on removing the 2 wood stringers installed now and redoing them.... Is the noodle to big to use on the floor of the hull? is there something else better for the floor?
I recently acquired a '66 DS1 and started to clean her up. After removing the 2 boards that provide support between the seats and the CB I noticed that ther was some flex along the centerline of the hole. the CB housing has some flex left and right and you can see some flex in the centerline of the boat. not a lot but you can see it. It does have 2 stringers that were glassed in(not sure if that was factory or aftermarket...)
jpclowes wrote:I recently acquired a '66 DS1 and started to clean her up. After removing the 2 boards that provide support between the seats and the CB I noticed that ther was some flex along the centerline of the hole. the CB housing has some flex left and right and you can see some flex in the centerline of the boat. not a lot but you can see it. It does have 2 stringers that were glassed in(not sure if that was factory or aftermarket...)
Did you replace the thwarts between the seats and the CB trunk? They are absolutely necessary for the structure of the boat, and required by class rules. Without those the CB could fail.
Users browsing this forum: No registered users and 95 guests
