77-DS2 Crack in gelcoat near waterline
Hi group,
I'm a new and happy owner of a 1977 Daysailer II... and have already benefited from the past and recent discussions on your site. I attached a link with some pictures from when I got her... she had been sitting out in the weather uncovered at a storage yard for about 4 years... and is quite a mess... but everything is intact... and barring any centerboard issues, seems like she should be fine with a good cleaning and new lines. The sails were stored indoors are in great shape. The only major concern I have is a crack in the gel coat on the starboard side toward the rear. I don't think it's a fatal problem... but the crack is just above or at the waterline... and about 5" wide and 1/4" deep (as the pic with the inserted putty knife shows). I'd like to get it in the water soon while there is still some season left to enjoy but I need to know what if anything I should do about the crack.
My specific question is could I do nothing about the crack for now... with no serious consequences (and do a proper fix it this winter); or do I need to do something about it before I get it into the water... and, if so, can I get away with a quick fix for now (and do a more better fix during the winter) OR do I need to fix it correctly now (and if so, how long is that likely to take, what wd be best to use, etc., etc.).
http://picasaweb.google.com/dbk0630/77DS2?feat=directlink
A friend suggested that I do a quick fix using "Splash Zone" and get her in the water now... and repair it properly later. He described "Splash Zone" as a two-part epoxy that you mix and apply... even if the crack is under water.
http://www.go2marine.com/product.do?no=79357F
TIA...
TIA...
