Fall haulout
Fall haulout
Postby kokko » Mon Sep 28, 2009 8:11 am
I made a small discovery that I thought I would share. It is fall here in MN, and it's time to haul the boats and prep for storage.
I start with a thorough cleaning - in and out. Last spring I had my DS1 bottom painted, so the bottom cleaned with just the garden hose. As usual, the water line was dirty - covered with that weird mix of algae, oil, and associated filth. I started scrubbing witha scrub brush, but that didn't work. A sponge was useless. On a whim I tried 000 steel wool in a Dawn detergent solution, and that did the trick. the 000 is very fine and did not scratch.
After the scrubbing with the steel wool, and rinsing, I polished the boat with polishing compound using a power buffer, then applied a coat of marine wax. THe boat looks great.
DS1 Truelove
Postby markst95 » Tue Sep 29, 2009 4:32 pm
Be careful using steel wool, it can leave pieces of itself lodged in any nooks and crannies. The steel wool then rusts and can leave stains. I prefer to use a scotchbright pad, should work.
markst95
cleaning
Postby kokko » Tue Sep 29, 2009 4:35 pm
I tried Scotchbrite and foudn the 000 steel wool worked better. Note that I followed that up with polishing compound (which contains no wax) and buffed that off. I think the polishing would remove any fines from the steel wool.
DS1 Truelove
Postby seandwyer » Tue Sep 29, 2009 5:03 pm
All this talk about hauling out for fall - you guys are depressing me. :(
Sean
DS1 - 3203
seandwyer
Postby jpclowes » Wed Sep 30, 2009 8:41 am
Sean
Don't worry too much, we sail until the first of November here. You could probably go longer since you are south of us.
J .P. Clowes
DSI 14083
jpclowes
Postby Marv Irwin » Wed Sep 30, 2009 9:12 am
Hey Kids,
The forecast here in Sudbury, Ontario (Canada) is for a high of 2 degrees (Celsius)....about 35 or 36 F. with a chance of flurries..... and my boat's still in the water. Until the lake gets really hard, keep the faith!
Marv
Marv
Marv Irwin
Postby seandwyer » Wed Sep 30, 2009 11:06 am
OK Marv - you've got me. That does sound more rigorous than our puny little frost warning here in Southern Ohio!!
Sean
DS1 - 3203
seandwyer
Postby MrPlywood » Wed Sep 30, 2009 6:00 pm
Here in Victoria BC, the Bermuda of Canada, we're all whining because it's 57 degrees today. :) This weekend's sail will be cooler than last weekend for sure, but it's still an enjoyable day. Just no swimming at the island picnic stop.
MrPlywood
Users browsing this forum: No registered users and 41 guests
