New owner of 1966 DS1
I'm the new owner of an approximately 1966 DS1, based in Maine.
I've so far got lots of great information from this forum, so thank you all!
The boat is old, but the previous owner took good care and put in lots of work: new standing rigging, newer running rigging and sails, re-varnished woodwork, and more.
There are a few things I'd like to add, especially for sailing in the windier conditions and chop of Penobscot Bay in Maine:
1. Reefing lines and hardware (the main already has reefing points)
2. Boom vang
3. Better outhaul setup
4. Cunningham
5. Tiller extension
6. Hiking straps
Most of these will probably be winter projects. For now, I'll just focus on getting in a few more outings before the end of the season.
Other maintenance things I'm eyeing up: repainting the hull (it has a lot of crazing, but it's very even so I suspect is age and UV, not anything more serious); reinforcing the cuddy (some cracks on the corners of the opening); inspection ports in the benches. But I'm going to ignore these for now, and maybe consider how important they are after more sailing.
A few questions:
1. How much of a drip/leak from the centerboard handle is normal? The current rate doesn't seem concerning, but does any leak at all call for a replacement gasket?
2. What is the usual main sheet "traveler" set up on a DS1. It's hard to tell from photos online. At present, the setup doesn't allow the main sheet blocks to move along the traveler line, and I'm OK with that cause the alternative is a traveler that is basically always at its leeward limit. But is there another way to rig it so that it functions like a track traveler and can be used to pull the boom to windward?
3. Does anyone have experience with a half-decent rowing set up for a DS1? I know it's never going to be that fast, but could be more efficient than paddling. Basically, it would be nice to cover that last half mile or so without an engine when the wind dies.
2. Boom vang
4. Cunningham
5. Tiller extension
6. Hiking straps
A few questions:
