Sealing the Hull CB slot
Hi, it is quite commonplace in Australia to fix a slotted tape along the opening of the CB case of dinghies, flush with the underside of the hull. This tape is quite rigid but split along its centre so that when the CB is lowered it fits quite tightly and therefore greatly reduces the amount turbulence and pressure inside the CB case. It also reduces the drag of the hull.
Does anyone have experience fitting such a seal on a Daysailer?
Cheers Greg
Cheers Greg
