Does your Day Sailer I centerboard leak?
Postby Guest » Thu Apr 02, 1998 1:00 am
Does your centerboard leak? Day Sailer I Centerboard Handle Gaskets available! Fleet 23 has them at cost. $3.25 per gasket, plus $.75 per gasket for shipping, Please send order and check
payable to:
Alan T Jones
Suite 840
621 SW Alder
Portland, OR 97205-3623
(503) 241-2575
Gus Heismann (gheismann-at-hotmail.com)
Postby Guest » Thu Jun 22, 2000 12:00 am
Can anybody tell me if the gentleman listed here is still currently selling centerboard gaskets? Thanks E
Eric J. Nelson (nelsonjnelson-at-msn.com)
Postby Guest » Mon Jun 26, 2000 12:00 am
Well, if not....you can get them from either Cape Cod Shipbuilding (current DS builder) or D&R Marine.
However, I saw the ad from fleet 23 in the latest Day Sailer Quarterly (DSA newsletter) so I would assume they still sell the gaskets.
Just in case; D&R Marine 508-644-3001
Cape Cod Shipbuilding 508-295-3550
You can also get the washers at your local hardware store for about $1.00 each. They are 3" outside diameter, with a 1" hole. I replaced mine several years ago, sandwiching a disc of thin plastic sheet between them to act as a bearing. They are just starting to show wear now, but don't leak a drop.
Lee Peterson (leep-at-means.net)
Postby Peter McMinn » Mon Oct 27, 2003 7:22 pm
Hi, I just wanted to find out more about the gaskets you described for your DS1 CB handle. In which isle did you find them at the hardware store, plumbing? How thick are they? I like the idea of the outer seal moving with the handle. Did you mean that you installed two of these gaskets with the plastic between them?
Peter
Peter McMinn
Postby Peter McMinn » Thu Dec 08, 2005 6:11 pm
Alan Jones, listed in the 1st message, is still selling the gaskets!
Peter McMinn
