"fast entry" cam cleats?
Hello, All,
Our DSI (circa 1961) has what must be her original jib sheet cam cleats mounted on the insides of the coaming, port and starboard.
They are the kind we all know and love, made of that unique form of linen that is hardened and lasts forever. I have no problem with what the cleats are made of. In fact, I'd love to keep them -- if only they were easier to use. But they're not, they are stiff and they open with great reluctance.
They used to work better (somewhat) when they were set on angled bases, so that one didn't need to rub one's hand raw against the coaming for every re-cleat. They are now on flat bases because I wanted to secure the cleats better and installed machine screws all the way through the coaming with nuts on the ends, rather than continue with the wood screws which working their way loose.
Anyway, barring someone's advice on how to improve their functionality, I think that new cleats might solve the problem. I've seen and played with the "fast entry" type by Schaefer. They seem dreamlike to use. Will that solve the problem, or did I make a big mistake by mounting the old cleats on flat bases? In other words, will these new, easy-to-engage cleats be enough to make the difference even lying flat?
