I have a '68 DSI I am restoring (lot's of work on just about everything)
I am now in the process of reconditioning the mast. (sanding, adding a tabernacle [the mast had already been cut for a tabernacle but then re-sleeved], new spreaders and brackets, etc).
I measured my mast and checked it against the By-Law 3 Specifications and Measurements which states that "from the top of band 1 (mast datum) to the bottom of band 3 the mast should be 22' 6"." And according to the diagram, the top of band 1 is at the top of the mast hole of the cuddy.
My mast measures out at 24' 6" from the bottom of the mast to the top of band 3 (not including the masthead). And for reference I checked the DR mast length for a fully complete mast and they specify a complete DS I mast as 24' 7". So this all seems to check out.
So here is the problem. At 22' 6" (band 1 to band 3) with a 24' 7" total overall length, that leaves 2' 1" for the mast from the top of the cuddy to the bottom of the DS I hull step.
But my length from the cuddy hole to my mast step is 29". The mast step is a large round brass ring which turns on a large brass screw so it can be adjusted up and down, but even with this amount of adjustment it could never be shortened to the needed distance of about 25".
Here is my question. Does anyone else have a DS I set up like this and if so what is your mast length? What is your length from the top of the cuddy to the mast step which is mounted on the center member of the hull bottom?
It looks like even if I purchased a new mast from DR it would be too short and I would have to modify the mast step to make it work.
I am missing something here?
