Gudgeons/transom connection
Postby John Stevens » Tue Apr 29, 2008 10:36 pm
I just bought a DS1 Spindrift yesterday. There is a small block of wood between the gudgeon and the transom. Is that a factory setup? The wood is old and I'm going to reseal and replace the wood unless it's not a typical setup, thus I'll leave out the wood.
TIA,
John Stevens
Postby algonquin » Tue Apr 29, 2008 10:45 pm
I don’t believe that the wood spacer on the exterior of the hull is correct. Usually there will be a backing plate on the inside of the hull. I would remove it and check for any potential damage that may be there and address that issue. Sounds like someone attempted to strengthen the mounting surface. Brad
Postby Bob Hunkins » Wed Apr 30, 2008 1:16 pm
The wood may be there to bring the distance from the transom to the rudder pivot to the maximum allowed distance of 9". (See Figure 6.4 in the handbook)
It's probably not necessary to remove it, and replacing the wood if it's rotten is a preferable.
The current setup might also allow for a wider allowable rudder angle. consider that before deciding to remove this wood.
good luck,
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
Handbook and gudgeons
Postby John Stevens » Thu May 01, 2008 12:53 pm
Bob,
I don't have a handbook, do you have a picture of that Fig. 6.4?
What advantage is there to having the rudder further back?
TIA,
John Stevens
Postby Bob Hunkins » Thu May 01, 2008 4:13 pm
There's a copy on this website. Go to The "Day Sailer Association" link at the top of the page and select "Handbook". Then select "Part 3: Specifications and Measurements" and find Figure 4.6.
I think the reason for this is to increase the moment arm of the rudder force to turn the boat. It's added leverage, which means less force for the helmsman to assert on the tiller. If anyone else knows the reason, I'd like to hear it.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
Postby John Stevens » Thu May 01, 2008 6:38 pm
Bob,
Thanks for the link. It must be an advantage if you're only allowed "so" many inches.
John Stevens
Postby algonquin » Fri May 02, 2008 9:12 pm
Could be that the water is just slightly less turbulent as you move back away from the hull.
