Build Plate
Build Plate
Postby algonquin » Sun Sep 30, 2007 10:36 pm
Do all DS models have a build plate some where on the hull ? Can't seem to locate one on my DS1.
1972
Postby Roger » Mon Oct 01, 2007 8:39 am
Only boats built after Nov 1, 1972 required manufacturers to attach a HIN or hull identification number. Some manufacturers before did attach a built plate or HIN but there was not uniformity. After 1972 the HIN were required to be on the transom, and one other inconspicuous place.
Postby navahoIII » Mon Oct 01, 2007 11:15 am
Ours is circa 1963 (class # very low 1000s) and it has a metal (brass?) plate with the make, hull and class numbers attached to the center of the transom coaming (mahogany). Still have all your coaming?
navahoIII
Postby jpclowes » Tue Oct 02, 2007 1:02 pm
My builders plate is right between, and slightly below the two openings for the foreward locker. It is a little metal (aluminum, tin?) plate with the billder information stamped in, and the hull and class numbers etched in, it looks like, by hand. My boat is a 1965, DS1 Sail # 1868.
Hope that helps.
J .P. Clowes
DSI 14083
jpclowes
Postby Adrift » Tue Oct 02, 2007 7:42 pm
As the others have said....
However, it may not be a "plate" affixed to the hull. Often it is a plate placed in the mold and when the boat is laid up it leaves an imprint in the gel coat.
Adrift
Postby Bob Hunkins » Tue Oct 02, 2007 8:23 pm
You might try looking on the bows just under the rubrail. Sometimes there's a number there. I have O'Day boat #1795 that has a Gel coat impression of a number, but it is The O'Day serial number, not the class number.
Bob Hunkins
#11750, "Surprise"
San Leon, Texas
Bob Hunkins
Site Admin
Users browsing this forum: No registered users and 61 guests
