Mast step loose-- please advise
Hi:
After reading through these posts, I tightened up the shrouds and removed the upper mast stays. We took the boat out last week and had it planing. It definitely seems to sail better.
However, as a result (I think) the mast step has come loose. I took it apart today and found that one of the #8 screws apparently sheared off, or maybe just failed from corrosion. The hole into the keelson is bored out. The other screw is still secure in a proper diameter hole. There doesn't appear to be any support behind (under) the fiberglass on the keelson.
Can someone please advise me on what the DS1 mast step set-up should be? The only info I can find looking back in the repair posts applies to the DSII.
Wyatt
Wyatt
