drain hole in hull
drain hole in hull
Postby calden » Thu Oct 06, 2005 9:44 pm
Hey all:
Cleaned up the new boat today (see "New DS Questions" thread a few days ago) and found the drain hole in the hull, immediately aft of the centerboard compartment. It's about 1/3" in diameter, and just a hole, no housing or collar or anything.
Shouldn't it have some kind of a check valve? Certainly I can't put it in the water like this. Where can I obtain the right fitting/valve to replace this?
I'm intending to take this out on Saturday - if I need to I can put a cork in temporarily.
Carlos
calden
Postby michaelyogi » Thu Oct 06, 2005 11:15 pm
Hi Calden
Gotta' DS1 in Eastern WA also and I couldn't help but notice your thread. My DS has a stopper in the drain hole. This stopper is just like the ones in the old thermos bottles, with a rubber body and a metal flip lever on the top. Your right, you gotta' have something in the hole or else it gets wet in the boat real quick. Good luck and good sailing...
michaelyogi
Postby calden » Thu Oct 06, 2005 11:24 pm
michaelyogi wrote:Hi Calden
Thanks - I thought it would be something like that. I'm in Spokane, and intend to go to Lake CdA and Pend Oreille as much as possible. In fact I'm going out for a maiden voyage on Saturday.
Carlos
calden
Postby michaelyogi » Thu Oct 06, 2005 11:52 pm
Keep in mind Carlos, that I've had my DS only one year and I 'm no expert by any stretch of the imagination. This boat was purchased out of Port Townsend and was basically "cobbled" together in order to sell to some poor sucker like like me. But love is blind... I sailed her four times last fall then put her into my shop to work on her for the winter. Unfortunately she's still there but looking better than when I purchased her. Hopefully she'll be out soon. Just waiting on the last few parts. By the way I'm in the Methow valley. I sail on some small local lakes, the Columbia river, Banks lake, and of course Puget Sound.Have fun Sat.
michaelyogi
Postby calden » Fri Oct 07, 2005 12:08 am
michaelyogi:
I'd love to hear where you find good sailing up around where you are. I'm looking to take this thing lots of places, and mountain lakes sound great.
Carlos
calden
Postby Mike M. » Fri Oct 07, 2005 7:21 am
You are lucky, Carlos. I didn't discover that little drain hole aft of the centerboard trunk until AFTER I launched the first time!! Then of course, couldn't find a plug, had to whittle a stick real fast. Did eventually find a plug, and it's threaded. I want to say it's a 3/8" and I found it in the plumbing section at Lowe's. Now I have two extras tucked away and the original whittled stick.
Good sailing
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby neisenl » Thu Oct 27, 2005 9:29 pm
I have a drain hole aft of centerboard well. My boat (Hull 3002) came with a threaded plastic or delrin plug, with a screw slot.
I did install 2 drain plugs on transom, about 1 inch above "floor". This helps drain most of water from rain, washing, accumulation , etc, with just a small tipping of bow.
Neisen
neisenl
Postby calden » Fri Oct 28, 2005 12:52 am
neisenl wrote:I have a drain hole aft of centerboard well. My boat (Hull 3002) came with a threaded plastic or delrin plug, with a screw slot.
Neisen
Hey - thanks for the reply. I figured out that is exactly the kind of plug I have. I found the threaded plug sitting in another part of the boat - hadn't noticed it. I bought a spare just in case.
I'm considering installing a transom drain plug as well. The centerboard well drain sits in a little built-up area, and water doesn't totally drain from it. It would be nice to have it all flow out the back.
Carlos
calden
Users browsing this forum: No registered users and 61 guests
