Wire Halyard Size
Wire Halyard Size
Postby John Stevens » Thu Jul 24, 2008 8:50 pm
I read the specs for the wire halyards at 1/16. I've had a hard time finding the rigging locally. I can find 3/32 with the thimble and all put together. Can I use this?
Also, getting the exact lengths right- Main halyard- is it 23 feet of wire from end to end or from loop to loop after it's bent around a thimble?
The place that sells the wire can put it together for me.
John Stevens
Postby Bob Damon » Mon Jul 28, 2008 4:14 pm
3/32 is fine, 1/8 is better and usually not much more expensive. Good luck, Bob Damon
Bob Damon
Class Measurer
Postby markst95 » Mon Jul 28, 2008 10:49 pm
why don't you use a rope halyard? The new lines are plenty strong enough, I used one on mine ds2 and it worked great. you can get low stretch lines that are perfect.
markst95
Users browsing this forum: Google [Bot] and 2 guests
