Guy deck fitting
Guy deck fitting
Postby prochase » Mon Mar 16, 2020 12:00 pm
Can anyone provide a source for this deck fitting? I plan on rigging the boat with a spinnaker
Thank you,
Eric
prochase
Re: Guy deck fitting
Postby tomodda » Mon Mar 16, 2020 12:31 pm
It's from Ron and Stan, West Marine sells it:
https://www.westmarine.com/buy/ronstan--spinnaker-brace-hook--2500122
A suggestion, look at Phill Root's "Rigging a Winning Daysailer" page on the our parent daysailer.org site. Instead of using a guy hook on deck, Phill simply puts a pulley sheave (actually, a becket roller, small sheave) on the outboard side of his chainplates. I think it's a more elegant solution - the guy stays put when the pole is forward and pops out when it's back, then auto-releases when you jibe. As Phill writes: No more trips to leeward to release a forgotten line.
Alternatively, there is this:
https://www.amazon.com/Stainless-Ceiling-Hangers-Straps-Rigging/dp/B07HVNMLKX/
Stainless, just put a backing plate under it, and use a nut and bolt to fasten.
Anyway, all the best with the rigging project!
Postby GreenLake » Mon Mar 16, 2020 12:56 pm
This one here:
https://www.fisheriessupply.com/ronstan ... -hook-rf91
You may want an RF92 instead, without the through bolt. None of the catalogs list dimensions. Perhaps best to try to call before you order.
Postby GreenLake » Mon Mar 16, 2020 1:01 pm
Tom was faster. The key thing about the Ronstan fitting is that it has the little neoprene toggle to prevent the guy from leaving the brace hook without a positive tug.
Postby tomodda » Mon Mar 16, 2020 2:21 pm
>Tom was faster.
Not a race! :) And yes, I had a niggling memory that Ronstan builds this deck fitting without the long thru-bolt. RF-92 it is.
I saw one of these at Fisheries Supply in Seattle (great store!), but didn't handle it. So the neoprene toggle is just a "soft button" then? Doesn't really click the guy into place, it just helps hold it in position via friction?
Postby GreenLake » Mon Mar 16, 2020 2:26 pm
Haven't seen any of these up close and personal yet.
Postby prochase » Mon Mar 16, 2020 2:52 pm
Thanks guys,
This is a great forum!
Eric
prochase
Users browsing this forum: Bing [Bot] and 52 guests
